Quantumn
Sep 30, 2017Aspirant
VLan not VLanning on GS728TP
Have several cameras which I'd like to put on their own vlan. And I have a server that handles those camers, which I'd like on the camera vlan and default vlan. I find that the GS728TP has 3 default v...
- Oct 19, 2017
Here is how it should be configured as shown in the image below provided that all devices are within the same subnet:About port 3 where the camera server is connected on VLAN 4, it should be set as untagged (U) with PVID 4. It should also be set as untagged (U) on VLAN 5 to have communication to the cameras connected to ports 14, 16, 18 and 20.
For ports 14, 16, 18 and 20, it should be set as untagged (U) with PVID = 5. These ports should also be set as untagged (U) on VLAN 4 in order for the camera server to have access to the cameras.
About port 23, I did not know that it is the LAN printer. Port 23 should be on VLAN 4, untagged (U) and PVID = 4.
About port 2, you may set it as a member of VLAN 4 (if ever you want it in VLAN 4) set as untagged (U) with PVID = 4.
You can use the default Voice VLAN for IP phones wherein an IP phone is detected by its OID (Object Identifier) and segment all voice traffic.
About the default Auto-Video VLAN, you can use it applications that run multicast traffic.
DaneA
NETGEAR Community Team
DaneA
Oct 16, 2017NETGEAR Employee Retired
Let us isolate the problem. Here are the steps below:
1. Connect 2 PCs to the ports of the GS728TP switch that belong to VLAN 4. Let us label it as PC1 and PC2
2. Make sure that the ports are untagged with a PVID of 4.
3. Check if the 2 PCs are able to get a valid IP address within the network range of VLAN 4.
4. From PC1, check if you can get replies when you ping the IP address of PC2.
5. From PC2, check if you can get replies when you ping the IP address of PC1.
Note: Do the same steps above but this time, connect the 2 PCs to the ports that belong to VLAN 5 and make sure its untagged with a PVID of 5. If you are able to get replies from each other PC, then it means that you have correctly set up VLAN 4 and VLAN 5.
If ever still you are having problems setting up VLANs on your GS728TP switch, I suggest you to open a chat or online case with NETGEAR Support for further assistance.
DaneA
Quantumn
Oct 16, 2017Aspirant
It doesn't work. I set the cameras server to PVID4 (so it can still communicate with the office LAN) and disable ingress filtering and set it to VLAN4. Then I set the cameras to PVID5 and VLAN5. But from the cameras server I then cannot ping -anything- including the cameras.
I need the cameras server to be able to communicate on both VLAN4 and VLAN5, but I want to isolate the cameras to VLAN5.
- DaneAOct 16, 2017NETGEAR Employee Retired
Just to verify. Kindly answer the questions below:
a. Were you able to perform the steps I suggested to isolate the problem?
b. Do the PCs get a valid IP address in either VLAN 4 or VLAN 5 as you proceed with the steps given? If not, kindly set a static IP address on the PCs that is within the IP range of VLAN 4 and VLAN 5.
c. Did you set up Asymmetrical VLAN?
d. Have you already opened a chat or online case with NETGEAR Support?
DaneA
- QuantumnOct 16, 2017Aspirant
a. I had to modify your steps as I have only 3 servers, 2 of which are mission-critical. So I used the non-mission-critical (cameras) server, and the cameras.
b. We do not use DHCP, we use static IP, and I made no changes to the IP addresses when I put the cameras and camera server on vlan5. When all on vlan1, all systems can see one another. When I put the cameras server on vlans 4 & 5, it disappears from the other systems. And from the cameras server I cannot ping the cameras.
c. I did exactly as I described above, which should be asymmetric vlan.
d. Support costs money, and this appears to me to be a defect in the firmware of the device, which is not my fault.
