toddhatch
Jan 19, 2024Follower
Remove management settings from a Netgear 4250 switch
I'm in a crunch. Need to know how to go about disabling switch management. Client request.
schumaku
Jan 19, 2024Guru - Experienced User
You can't disable the switch management with just one click. Please restrict Management Access using Access Control instead, for instance https://www.netgear.com/support/product/m4250 -> AV Line of Fully Managed Switches M4250 Series Software Administration Manual Firmware Version 13.0.0 , Configure a Management ACL, starting from p. 176.
