yakamoneye19
Mar 23, 2022Aspirant
Remove Second DHCP MAnagement IP
Hello Everyone, we have multiple Netgear switches (3300, 5300, 4300... - current firmware) and on most of them we have the same behavior. Let's say we have two networks. One is the main offi...
yakamoneye19
I am not sure if I understand your reply - I am looking for a way to prevent my Netgear Switches from creating a second management IP via DHCP on connected VLAN 1 after I created a fixed IP on another VLAN.
schumaku
Mar 24, 2022Guru - Experienced User
- schumakuMar 24, 2022Guru - Experienced User
Again, this isn't a secondary management IP as you know from some junky consumer router designs. Technically, these switches have by default an IP address on the OOB and in-band networks. If you don't want the management capabilities, you need to put ACLs in place (by network, by port).
By rule of thumb - considering the full config is accessible - I would guess it should be possible to disable it completely if you have no other dependency (L3 routing, DHCP, ...).
- yakamoneye19Mar 24, 2022Aspirant
So there is no easy way to prevent that the switch is accessable from the network running on VLAN 1? I have to say I really do not understand this design choice, and I do not like it. Even if we block management access to this IP, we still have 1 address blocked in the DHCP range per switch, and from a security perspective, the most secure way to protect a system is to remove it from the main network. I understand that this is not possible in an easy way - from a security perspective a really stupid and dangerous setting in my opinion.
