RJ248842
Apr 24, 2020Aspirant
Request for part numbers
We're looking to set up a network for an SMB. The switches will be Netgear M4300-52G-PoE+. For this switch, we'd be grateful for part numbers for the highest performance/highest power models of the f...
- Apr 24, 2020
Hi RJ248842
Thank you for reaching out to the Community. You may use the M4300 datasheet for selecting your accessories starting page 26.
Redundant PSU: depending if you have a 550W PSU already or a 1000W PSU, you can add a second APS550W or a second APS1000W for redundancy mode or power sharing mode. M4300 can do both at the same time. Different PSU can't be mixed and matched, but you can remove the APS550W and add two APS1000W if you need more power for instance. Ordering SKU numbers are APS550W-100NES and APS1000W-100NES.
Fiber SFP+ module (LC/LC) OM4 this is the AXM761 10GBASE-SR transceiver. Ordering SKU number AXM761-10000S.
Copper SFP+ module (RJ45) this is the AXM765 10GBASE-T (10G speed, no auto-neg, max 30m on CAT6A) or the AGM734 1000BASE-T transceiver (1G speed, no auto-neg, max 100m on CAT5E). Ordering SKU numbers are AXM765-10000S and AGM734-10000S.
I hope this helps,
Regards
LaurentMa
Apr 24, 2020NETGEAR Expert
Hi RJ248842
I hope this helps,
Regards
- RJ248842Apr 24, 2020Aspirant
Merci beaucoup, monsieur.
