robfantini
Apr 25, 2017Aspirant
Routing Mode - which should I use.
Hello I have just got the 2 switches to stack. these are nice switches for a proxmox cluster. however I've a lot to learn. we have an internal network consisting of 20 vlans. pfsense is use...
- Apr 26, 2017
Hi Robfantini
Normally if the pings are not working is due to that you only have one way communication accross the network. You need to make sure that the packets also known how to return from the other networks.
The easiest way to address this is to set up some static routes in your main Switch or Router to make sure that you can reach the VLANs from there.
You can see an example in the below kb article( last section)
Hope it helps
XAvier Lleixa
NETGEAR CBU PLM
XavierLL
Apr 25, 2017NETGEAR Employee Retired
Hi Robfantini,
Welcome to our community!
I would suggest to turn it the routing on the inter-VLAN traffic so you will be able to improve the performance and also set up IP ACL to control the traffic.
I would recommend the following articles to have a look how to deploy it:
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
robfantini
Apr 26, 2017Aspirant
OK so I'll use routed mode . thank you for the help!
- robfantiniApr 26, 2017Aspirant
OK I'm making some progress.
current issue:
I can ping switch IP and log in.
Can not ping out from switch.
I've run in to that before, years ago..
One thing that complicates this is I've still got our cisco sg300 as main switch .
However I am using a completly different vlan/IP set up on the new switch.
Any hints to fix cna not ping out?
best regards.
- XavierLLApr 26, 2017NETGEAR Employee Retired
Hi Robfantini
Hope it helps
XAvier Lleixa
NETGEAR CBU PLM
- robfantiniApr 27, 2017Aspirant
XAvier Lleixa -
I reset the switch and followed the document . now vlan routing works perfect .
It is nice to see NetGear has great support.
