RugbyWreck
Feb 05, 2018Aspirant
Routing Question
Hi, I have a quick question with regard to a GS752TP switch. If I have a switch address (native VLAN) in the 192.168.10.0 network does the default gateway of the switch have to be in the same net...
- Feb 06, 2018
Hi RugbyWreck,
Well, it is actually recommended that the management IP of the switch and the default gateway should be on the same network. You cannot apply an IP to the switch outside its subnet address. IPs doesn't really matter to the switch. As long as it receives tagged and untagged traffic, it will work. The IPs in the switch will only matter for the management of the GUI.
JohnC_V
Feb 06, 2018NETGEAR Employee Retired
Hi RugbyWreck,
RugbyWreck
Feb 06, 2018Aspirant
Hi John,
Thank you for the answer. Whilst not ideal it may be the most expedient set-up for me in one particular situation and it's good to know that it should work even if it's not an expressly recommended solution.
Tom Burbury
- JohnC_VFeb 06, 2018NETGEAR Employee Retired
Yes and the management will only work if you do have Inter-VLAN routing enabled.
- RugbyWreckFeb 06, 2018Aspirant
I do have the rotuing enabled.
Thanks again.
Tom Burbury.
