jameswiltshire
May 20, 2019Aspirant
Routing Question
Hi,
I`m trying to route traffic on our switch to another switch but i`m struggling and need some help.
On switch 1 i have data vlan, VLAN 10: 10.0.10.0/24, and i need to connect to anoth...
- AnonymousMay 22, 2019
Welcome to the community!
Yes, correct!
You need create new routing VLAN that include port 50 that connect to partners side. Set an IP address same subnet as 10.23.31.0 for this routing VLAN. Then enable globle routing on Switch.
And in this scenario, you need not set static route for partners subnet, it will reach parters via directly connected route table.
Hope it helps!
EricZ
NETGEAR employee
Anonymous
May 22, 2019
Yes, correct!
Hope it helps!
EricZ
NETGEAR employee
