bluesound
Oct 11, 2017Aspirant
Routing with a VLANS - changing subnets
I inherited a network on a weird internal subnet (100.100.100.x) the gateway (issued by Windows DHCP server) for clients is a firewall and the switch isn't currently used for routing. I want t...
bluesound
Here is a quick network diagram which may help visualise this better.
JohnC_V
Oct 12, 2017NETGEAR Employee Retired
Hi bluesound,
Welcome to our community!
If you wanted to have the 2 VLANs to communicate with each other, then you might need to enable routing on those VLANs. As they are working on 2 different subnets. May I know the model number of your switch? You can also enable routing on your firewall.
