brunoabc
Mar 16, 2017Aspirant
S3300 10G uplink port used as normal
Can I use the 10G uplink/stacking copper port as normal port to connect for example a server with a 10Gb interface? Thank you
LaurentMa
Mar 16, 2017NETGEAR Expert
Hi brunoabc
Welcome to the Community!
Answer is yes. And S3300 Smart Managed Switches come with their four 10G ports preset in "Ethernet mode", so you can do that right out of the box, without any configuration.
For stacking, two of these 10G ports (copper, or fiber, or combination) can be configured for "Stacking mode" under System/Stacking.
I hope this helps!
- brunoabcMar 17, 2017Aspirant
Hi, Laurent.
Thanks for the quick replay.
Now I can buy a S3300!
Bruno
