Mettwurscht
Mar 09, 2023Aspirant
S3300-28X: Routing between two switches
Hi all, there are two buildings which are connected through a Wifi bridge. In building 1 is a LAN running on subnet 192.168.0.0/24, building 2 is running on subnet 192.168.1.0/24. Both buildings ...
- Apr 12, 2023I found the solution.1st mistake: management VLAN and routed VLAN must not be the same. You can use VLAN id 1 for a routed VLAN, but you have to change your management VLAN.These are the steps to a working setup:1.If you want to use VLAN id 1 for your network clients, go to VLAN menu and create a management VLAN. Assign a port to this VLAN if you want.2.Go to routing menu and use the VLAN routing configuration to configure an IP address for your switch. According to my example, I used this setting on site 1:VLAN: 1IP address: 192.168.0.10Subnet mask: 255.255.255.0On site 2 the settings are nearly the same:VLAN: 1IP address: 192.168.1.10Subnet mask: 255.255.255.0You can reach the web interface of the switch via its address you have configured here.Now you should assign a static IP address to your management interface. I experienced some issues when the management address is assigned by DHCP because I use subnet 192.168.0.0/24 for the clients on site 1.3.Go to VLAN routing wizard and create a new routing VLAN, e.g. 199Site 1VLAN: 199IP: 192.168.199.10Subnet: 255.255.255.0Port: 20 (untagged)Site 2VLAN: 199IP: 192.168.199.11Subnet: 255.255.255.0Port: 20 (untagged)In my setup I connect these ports to the Wifi bridge.4.Go to routing table menu and add two new rulesSite 1route type: staticnetwork address: 192.168.1.0subnet mask: 255.255.255.0next hop address: 192.168.199.11route type: DefaultRoutenext hop address: 192.168.0.250Site 2route type: staticnetwork address: 192.168.0.0subnet mask: 255.255.255.0next hop address: 192.168.199.10route type: DefaultRoutenext hop address: 192.168.1.2505.Go to routing menu and enable routing mode.6.Change the default gateway of your network to the switch's address 192.168.0.10 or 192.168.1.10.
Mettwurscht
Apr 12, 2023Aspirant
2.
VLAN: 1
VLAN: 1
3.
Site 1
VLAN: 199
IP: 192.168.199.10
Port: 20 (untagged)
Site 2
VLAN: 199
IP: 192.168.199.11
Port: 20 (untagged)
4.
Site 1
route type: static
Site 2
route type: static
5.
6.
