JeffAtK2
Jan 16, 2020Guide
Same VLAN and Subnet, Cannot Ping
Hi All, First, please be gentle, I'm just startung to venture into VLANs. I'm trying to isolate some ports so they're on a completely separate network from my office LAN. I want to use it for...
- Jan 16, 2020
Create the 802.1q VLAN ID (assume already done), each port for that storage VLAN must be set [U]ntagged for that VLAN only, and the same ID must be used as PVID. That's it.
The reason why you can't ping the other devices with their static IP config is that the incoming ICMP ping might go to the wrong PVID - this is defining where incoming untagged frames are associated to (which VLAN).
schumaku
Jan 16, 2020Guru - Experienced User
- JeffAtK2Jan 16, 2020Guide
Thank you! Setting the PVID for the ports in my backup network to matcch worked like a charm!
Jeff
