pmchenryx's avatar
pmchenryx
Setting DHCP Option(s) Problems on GSM7224P
I have several GSM7224P switches running firmware 10.0.1.21
I need to have the switches hand out IP and various options for my phone system to work.
I am hoping someone else has seen this or knows a way to fix this.
I am unable to add option 42 (NTP server) to my DHCP scopes
I have tried it via the web gui and cli
In the GUI I get an error that says Error! Failed to Add Option Code
In the CLI I get an error that says “ Couldn’t create option row “
On the GUI option I go into DHCP Server -> DHCP Pool Options
I select the:
POOL Name: Voice
Option Code: 42
Option Type: IP Address
Option Value: 10.1.1.12
In the CLI
Enable – config -> config
ip dhcp pool Voice
option 42 ip 10.1.1.12
I started trying other options and I got the same error adding
Option 5,6,7,15
I am able to add various other options via CLI
The web interface only allows you to enter 15 characters - *** nice bug ***
option 156 ascii ftpservers=10.1.1.10,country=1,language=1,layer2tagging=1,vlanid=129
option 43 ascii id:ipphone.mitel.com;sw_tftp=10.1.1.2;call_srv=10.1.1.2;vlan=129;l2p=6;dscp=46
  • I am curious, does anyone from Netgear look at these forums?
    I have had a support ticket open since 9/6 and cant get a response on this issue.
    I am told they are looking into it and they are sorry for the inconvenience.
    Generally no..
    forum is user to user only
    If you have put trouble ticket in try call in in the morning if you are in US(EST) and get level 2/3 on the phone
  • Hi,
    I am suffering the same problem. Both the option 42 doesn't work and I am not able to insert long options of DHCP on the web GUI.
    Aitor
ProSupport for Business
