rupertslander
Aug 19, 2023Follower
Simple configuration to prioritize one port for GS110TPv3
I have a very simple request - need to configure three ports on a GS110TPv3 Port 1 will be connected to the phone system Port 2 will be connected to the computer network Port 8 will be connecte...
schumaku
Aug 20, 2023Guru - Experienced User
No idea where you want to add anything ... such a switch does have a total bandwidth of 20Gbps full duplex
network with the full speed available port-to-port, and a latency of less than 4 μs for 64-byte frames in store-and-forward mode for 1000Mbps to 1000Mbps transmission. The maximum such a switch can do for any of the 1 GbE ports. Any throttling would be configured by the admin on the ingress and egress on each port.
