johnny6
Nov 01, 2011Aspirant
Smart switches question
Can these switch ports be set up to only allow one connection? For example, if someone decided to hook up a router or another network switch to one of the ports, they would only get one IP address? ...
jmizoguchi
Nov 01, 2011Virtuoso
layer2 switch should able to assign specific mac address to each ports. meaning you will not hang off a switch behind from that ports unless switch behind another switches will have also configure that each ports going to each wall outlet specify with correct mac address.
