henrylaw
Mar 23, 2018Tutor
Smartwizard fails to discover GS748T on same segment
GS748T v2 running V1.0.3_06. Test network is connected to a Netgear FR114P which is serving 192.168.10.0/24 DHCP addresses. Factory reset on the GS748T ends up with it on 192.168.10.51 (found by ...
- Mar 27, 2018
Well, that was easy. It's official: SmartWizard 2.5.5 does not work on Windows 10.
I found the one W7 machine I still have, dragged the switch away from the testbench to where the desktop PC was, connected everything, set IP addressing appropriately and SmartWizard went off with a roar.
Thank you for your help.
DaneA
Mar 26, 2018NETGEAR Employee Retired
Hi henrylaw,
Let us isolate the problem. If ever you have another PC such as a Windows 7 PC, I suggest you to install the NETGEAR Smartwizard Utility v2.5.5 in it then connect it directly to a LAN port of the GS748Tv2 switch and check if it will be detected.
If ever the GS748Tv2 switch got detected, I advise you to upgrade the firmware in a ladderized manner. The current firmware v1.0.3_0 you have in the GS748Tv2 switch is a very old firmware version and its not advisable to update it straight to the latest version. I suggest that you first upgrade the firmware from v1.0.3_06 to v1.0.3_08. Then, upgrade the firmware from v1.0.3_08 to v1.0.3_10 and so on until you reach the latest v3.0.7. Be reminded to perform a factory reset on the switch after upgrading to the latest version then reconfigure the settings from scratch in order to start clean using the latest firmware.
DaneA
NETGEAR Community Team
- henrylawMar 27, 2018Tutor
