klam238's avatar
klam238
SNMP MS510TXUP-100NAS
Hi,
I have ordered a new switch MS510TXUP-100NAS. Is possible to query wattage / voltage / current used in EACH port with snmpget v2. I see this data displayed on the webpage UI but can't find a way to see this via snmp.
I'm well aware that I can get the total power in wattage across all ports by doing:
snmpget -v2c -c [community] [switch_ip] SNMPv2-SMI::mib-2.105.1.3.1.1.4.1
Is this also possible for the GS510TLP?
  • schumaku's avatar
    schumaku
    The supported MIBs are listed on the devices under System -> SNMP -> Supported MIBs.
    The RFC 3621 Power Ethernet MIB, December 2003, does define the Management Information Base (MIB). In particular, it's a set of MIB objects to manage Power Ethernet [IEEE-802.3af] Power Sourcing Equipment (PSE).
    POWER-ETHERNET-MIB The MIB module for managing Power Source Equipment (PSE) works according to the IEEE 802.3 Powered Ethernet standard.
    The only power numbers available in the SNMP MIB are;
    pethMainPsePower 1.3.6.1.2.1.105.1.3.1.1.2 The nominal power of the PSE expressed in Watts.
    pethMainPseConsumptionPower 1.3.6.1.2.1.105.1.3.1.1.4 Measured usage power expressed in Watts.
    Different from the Web UI, there is no standardized MIB for the power usage per port.
    • klam238's avatar
      klam238
      Ok, so it looks like GS510TLP has measuring capabilities because it supports NETGEAR-POWER-ETHERNET-MIB
      However, MS510TXUP does not list NETGEAR-POWER-ETHERNET-MIB, so I'm concluding it's not possible to measure on the POE++ switch
      Is that correct?
      Is there a firmware upgrade or something that would get NETGEAR-POWER-ETHERNET-MIB to work on MS510TXUP?
      • schumaku's avatar
        schumaku
        Haven't spotted any updates or deployments of the fastPathpowerEthernetMIB for a longer time on newer products - would be nice to have of course:
        NETGEAR-POWER-ETHERNET-MIB DEFINITIONS ::= BEGIN
        -- Copyright Netgear Inc (2003-2015) All rights reserved.
        -- This SNMP Management Information Specification
        -- embodies Netgear Inc's confidential and proprietary
        -- intellectual property. Netgear Inc retains all title
        -- and ownership in the Specification including any revisions.
        -- This Specification is supplied "AS IS", Netgear Inc
        -- makes no warranty, either expressed or implied,
        -- as to the use, operation, condition, or performance of the
        -- Specification.
        IMPORTS
        MODULE-IDENTITY, OBJECT-TYPE, Integer32, Gauge32 FROM SNMPv2-SMI
        TruthValue FROM SNMPv2-TC
        ng700smartswitch FROM NETGEAR-REF-MIB
        DisplayString FROM RFC1213-MIB
        pethPsePortEntry, pethMainPseEntry FROM POWER-ETHERNET-MIB;
        fastPathpowerEthernetMIB MODULE-IDENTITY
        LAST-UPDATED "201803020000Z" -- 02 Mar 2018 12:00:00 GMT
        ORGANIZATION "Netgear Inc"
        CONTACT-INFO ""
ProSupport for Business
