Agsy's avatar
Agsy
Some questions regarding redundant setup with M4300 series switches - VMware Environment
Hey guys,
we are planning to deploy new redundant Netgear Switches (M4300 series), mainly as a replacement for our currently in place core switch (also Netgear). We plan to use 2 M4300-12x12f, combined with a M4300-28G in a stack. We'll also deploy three new VMware hosts with 2 10GBASE-T interfaces each, attached directly to the redundant M4300-12x12f switches in LAG configurations.
The 12x12f Switches will be uplinked via fibre to our redundant Sophos SG230 Firewalls (LAG defined in Sophos)
Here's a quick sketch I did to explain visually what we plan to do:
As I am new to stacked switches, I have some questions. Some of these questions might be stupid, so please accept my apalogies in advance ;)
1.) Is it best practice to connect the stack in a "circle" as I did in my sketch?
2.) I understand that the stacking is mainly for configuration simplification and not for inter-switch data transmission. Therefore, should I use 10G or 1G interfaces for stacking?
3.) I still need interconnects between my switches, therefore I use redundant 10G uplinks configured in a LAG and VLAN trunks (the interconnects are missing in my sketch, in case you wonder)?
What do you guys think? Thanks a lot in advance for any help.
Cheers
Sascha
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi Agsy,
    Welcome to NETGEAR community!
    1.) It is recommended to stacking in a "circle".
    2.) inter-switch data transmission also over stacking ports,and please use 10G to stacking.
         For detail setting, you can look into "http://www.downloads.netgear.com/files/GDC/M5300/M5300-M6100-M7100_SWA_v11_28Mar2015.pdf" capture 24 page 473.
    3.) It is not necessary to add interconnection between switchs. Switchs in stacking mode is working as one device.
    May the answers help you.
    • Agsy's avatar
      Agsy
      Hi Carl_z,
      thank you for your quick and valuable response, that helped a lot. All seems to work now as planned.
      Cheers
      Sascha
ProSupport for Business
