LgProjects
May 08, 2019Tutor
SSDP PROTOCOL (DLNA) NOT WORKING BETWEEN VLAN
Hi,
I have a stack of n. 6 M4300 switches with various VLANs and active routing.
I need to activate the discovery of the SSDP protocol between 2 vlan, because android application on vlan 1 does not fi...
- May 13, 2019
Below is the solution to the problem. In any case, the discovery is not immediate (it takes a few seconds).
Here are the commands to execute on Putty
(L3-SW1)>enable
(L3-SW1)#configure
(L3-SW1)#ip multicast
(L3-SW1)#ip igmp
(L3-SW1)#ip pim dense
(L3-SW1)(config) #interface vlan 10
(L3-SW1)(interface vlan 10) #ip igmp
(L3-SW1)(interface vlan 10) #ip pim
(L3-SW1)(interface vlan 10) #exit
(L3-SW1)(config) #interface vlan 20
(L3-SW1)(interface vlan 20) #ip igmp
(L3-SW1)(interface vlan 20) #ip pim
(L3-SW1)(interface vlan 20) #endWith gui:
-Switching
-Multicast
-Igmp Snooping (ALL ENABLE)
-Igmp Vlan Conf (Enable Vlan Ineresting)
-Multicast Router Vlan (add Vlan and Enable)
-Querier Configuration (Enable
-Querier Vlan Configuration (add ip Router VlanA+VlanB)
-Routing
-Multicast
-Glabal Configuration (Enable)
-Interface Configuration VLANS (VlanA+VlanB TTL2 "if necessary"
-IGMP (Enable)
-Routing Interface (Enable VlanA+VlanB)
-PIM Global Configuration (Enable PIM-DM)
-PIM Interface Configuration VLANS (Enable VlanA+VlanB)
---------TO MODIFY PIM-DM IN THE FUTURE, YOU MUST FIRST DEACTIVATE PIM INTERFACE CONFIGURATION----------
schumaku
May 08, 2019Guru - Experienced User
Start your adventure in the docs on the chapter of Multicast Routing ... further on it depends on what kind of streams you need.
- LgProjectsMay 08, 2019TutorOk Thanks .. I want to clarify one thing. I see device (NVR with unable DLNA) in vlan17 through "http" on pc windows 7 in vlan1 and I can see the video streamig, but I can't find via app (discoveryDLNA) on android device in vlan1. It's normal?
- schumakuMay 08, 2019Guru - Experienced User
Well, essentially DLNA was designed to run on a single broadcast domain (single subnet, signle VLAN) only.
Still, you can start trying to make UPnP SSDP - it's multicast - available, so the annoucements will become visible.
- LgProjectsMay 08, 2019TutoroK, can you give me some info to set? Multicast switch and multicast routing? I have already tried to set PIM and add UDP relay with port 1900. But nothing ...
