LgProjects
May 08, 2019Tutor
SSDP PROTOCOL (DLNA) NOT WORKING BETWEEN VLAN
Hi,
I have a stack of n. 6 M4300 switches with various VLANs and active routing.
I need to activate the discovery of the SSDP protocol between 2 vlan, because android application on vlan 1 does not fi...
- May 13, 2019
Below is the solution to the problem. In any case, the discovery is not immediate (it takes a few seconds).
Here are the commands to execute on Putty
(L3-SW1)>enable
(L3-SW1)#configure
(L3-SW1)#ip multicast
(L3-SW1)#ip igmp
(L3-SW1)#ip pim dense
(L3-SW1)(config) #interface vlan 10
(L3-SW1)(interface vlan 10) #ip igmp
(L3-SW1)(interface vlan 10) #ip pim
(L3-SW1)(interface vlan 10) #exit
(L3-SW1)(config) #interface vlan 20
(L3-SW1)(interface vlan 20) #ip igmp
(L3-SW1)(interface vlan 20) #ip pim
(L3-SW1)(interface vlan 20) #endWith gui:
-Switching
-Multicast
-Igmp Snooping (ALL ENABLE)
-Igmp Vlan Conf (Enable Vlan Ineresting)
-Multicast Router Vlan (add Vlan and Enable)
-Querier Configuration (Enable
-Querier Vlan Configuration (add ip Router VlanA+VlanB)
-Routing
-Multicast
-Glabal Configuration (Enable)
-Interface Configuration VLANS (VlanA+VlanB TTL2 "if necessary"
-IGMP (Enable)
-Routing Interface (Enable VlanA+VlanB)
-PIM Global Configuration (Enable PIM-DM)
-PIM Interface Configuration VLANS (Enable VlanA+VlanB)
---------TO MODIFY PIM-DM IN THE FUTURE, YOU MUST FIRST DEACTIVATE PIM INTERFACE CONFIGURATION----------
schumaku
May 08, 2019Guru - Experienced User
Start your adventure in the docs on the chapter of Multicast Routing ... further on it depends on what kind of streams you need.
LgProjects
May 08, 2019Tutor
Ok Thanks .. I want to clarify one thing.
I see device (NVR with unable DLNA) in vlan17 through "http" on pc windows 7 in vlan1 and I can see the video streamig, but I can't find via app (discoveryDLNA) on android device in vlan1.
It's normal?
- schumakuMay 08, 2019Guru - Experienced User
Well, essentially DLNA was designed to run on a single broadcast domain (single subnet, signle VLAN) only.
Still, you can start trying to make UPnP SSDP - it's multicast - available, so the annoucements will become visible.
- LgProjectsMay 08, 2019TutoroK, can you give me some info to set? Multicast switch and multicast routing? I have already tried to set PIM and add UDP relay with port 1900. But nothing ...
- LgProjectsMay 13, 2019Tutor
(L3-SW1)>enable
(L3-SW1)#configure
(L3-SW1)#ip igmp
-Switching
-Multicast
-Routing
-Multicast
-IGMP (Enable)
