LgProjects's avatar
May 08, 2019
SSDP PROTOCOL (DLNA) NOT WORKING BETWEEN VLAN
Hi, I have a stack of n. 6 M4300 switches with various VLANs and active routing. I need to activate the discovery of the SSDP protocol between 2 vlan, because android application on vlan 1 does not fi...
  • LgProjects's avatar
    LgProjects
    May 13, 2019
    Below is the solution to the problem. In any case, the discovery is not immediate (it takes a few seconds).
    Here are the commands to execute on Putty
    (L3-SW1)>enable
    (L3-SW1)#configure
    (L3-SW1)#ip multicast
    (L3-SW1)#ip igmp
    (L3-SW1)#ip pim dense
    (L3-SW1)(config) #interface vlan 10
    (L3-SW1)(interface vlan 10) #ip igmp
    (L3-SW1)(interface vlan 10) #ip pim
    (L3-SW1)(interface vlan 10) #exit
    (L3-SW1)(config) #interface vlan 20
    (L3-SW1)(interface vlan 20) #ip igmp
    (L3-SW1)(interface vlan 20) #ip pim
    (L3-SW1)(interface vlan 20) #end
    With gui:
    -Switching
                          -Multicast
                                                 -Igmp Snooping  (ALL ENABLE)
                                                 -Igmp Vlan Conf (Enable Vlan Ineresting)
                                                 -Multicast Router Vlan (add Vlan and Enable)
                                                 -Querier Configuration (Enable
                                                 -Querier Vlan  Configuration (add ip Router VlanA+VlanB)
    -Routing
                       -Multicast
                                                -Glabal Configuration (Enable)
                                                -Interface Configuration VLANS (VlanA+VlanB TTL2 "if necessary"
                                                -IGMP (Enable)
                                                -Routing Interface (Enable VlanA+VlanB)
                                                -PIM Global Configuration  (Enable PIM-DM)
                                                -PIM  Interface Configuration VLANS (Enable VlanA+VlanB)
    ---------TO MODIFY PIM-DM IN THE FUTURE, YOU MUST FIRST DEACTIVATE PIM INTERFACE CONFIGURATION----------
ProSupport for Business
