LgProjects
May 08, 2019Tutor
SSDP PROTOCOL (DLNA) NOT WORKING BETWEEN VLAN
Hi,
I have a stack of n. 6 M4300 switches with various VLANs and active routing.
I need to activate the discovery of the SSDP protocol between 2 vlan, because android application on vlan 1 does not fi...
- May 13, 2019
Below is the solution to the problem. In any case, the discovery is not immediate (it takes a few seconds).
Here are the commands to execute on Putty
(L3-SW1)>enable
(L3-SW1)#configure
(L3-SW1)#ip multicast
(L3-SW1)#ip igmp
(L3-SW1)#ip pim dense
(L3-SW1)(config) #interface vlan 10
(L3-SW1)(interface vlan 10) #ip igmp
(L3-SW1)(interface vlan 10) #ip pim
(L3-SW1)(interface vlan 10) #exit
(L3-SW1)(config) #interface vlan 20
(L3-SW1)(interface vlan 20) #ip igmp
(L3-SW1)(interface vlan 20) #ip pim
(L3-SW1)(interface vlan 20) #endWith gui:
-Switching
-Multicast
-Igmp Snooping (ALL ENABLE)
-Igmp Vlan Conf (Enable Vlan Ineresting)
-Multicast Router Vlan (add Vlan and Enable)
-Querier Configuration (Enable
-Querier Vlan Configuration (add ip Router VlanA+VlanB)
-Routing
-Multicast
-Glabal Configuration (Enable)
-Interface Configuration VLANS (VlanA+VlanB TTL2 "if necessary"
-IGMP (Enable)
-Routing Interface (Enable VlanA+VlanB)
-PIM Global Configuration (Enable PIM-DM)
-PIM Interface Configuration VLANS (Enable VlanA+VlanB)
---------TO MODIFY PIM-DM IN THE FUTURE, YOU MUST FIRST DEACTIVATE PIM INTERFACE CONFIGURATION----------
LgProjects
May 08, 2019Tutor
oK, can you give me some info to set?
Multicast switch and multicast routing?
I have already tried to set PIM and add UDP relay with port 1900.
But nothing ...
LgProjects
May 13, 2019Tutor
(L3-SW1)>enable
(L3-SW1)#configure
(L3-SW1)#ip igmp
With gui:
-Switching
-Multicast
-Routing
-Multicast
-IGMP (Enable)
