boe
Feb 10, 2022Luminary
Stackable POE switches that support 2.5gbps?
Hello, One of my clients has S3300 switches. We need to add 1 more switch with 2.5Gbs switch to each stack for new wireless APs. We'd like them to be managed as part of the stack and seen und...
schumaku
Feb 11, 2022Guru - Experienced User
The application notes are much older than the M4300-16X, so this is a valid question. LaurentMa svp.
LaurentMa
Feb 14, 2022NETGEAR Expert
Hi Team,
For mixed S3300/M4300 stack, please refer to: https://www.netgear.com/images/datasheet/switches/smartswitches/S3300-M4300-Mixed-Stacking-Application-Note.pdf and the associated KB: https://kb.netgear.com/000049533/Smart-M4300-S3300-Stacking-Notes-and-Restrictions
The procedure is explained here:https://kb.netgear.com/000049532/Smart-M4300-S3300-Firmware-Upgrade-Procedure
Latest S3300 firmware also explains this in the release note: https://kb.netgear.com/000063999?_ga=2.249224836.229795878.1644834875-18903587.1639681594
Only M4300 24-port 10G models below support this:
- M4300-12X12F XSM4324S
- M4300-24X XSM4324CS
I hope this helps,
