M0nde0
Jun 21, 2016Aspirant
Stacking GS748T with XS712T - Is it possible?
So it is possible to stack these two models of switches?
Hi M0nde0,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- JohnRoNETGEAR Employee Retired
Hello M0nde0,
Welcome to the community!
Regarding your question, the XS712T and GS748T are not stackable switches. Notice the model numbers of our switches, the ones that end in "S" are the ones that are stackable and that should belong to the same switch family. If you are planning to connect the XS712T and GS748T to other switches using SFP, that one is possible.
Feel free to ask if you have more questions.
Thanks,
- M0nde0Aspirant
Oh, I went to check the model of the switch.. its actualy GS748TS (so stackable)..
So if I buy XS712T it is possible to "SMART" stack it with older GS748TS?
tnx for answare!
Hi M0nde0,
Okay, so it is a GS748TS then yes, it is stackable. However, this does not mean that it will stack with XS712T since they do not belong to the same switch family. In this context, a stack port allows the switches (if they are of the same family) to be connected in a stack and managed as a single unit. Since your switches belong to different families they cannot be stacked, you will have to take the switches out of "stack mode" which is usually the default and configure the stack ports as uplink or trunk ports (if you are using VLANs) - once this has been done you should be able to link the switches via the fibre ports, assuming you are using compatible and matched SFP modules. For more information, please click here.
Thanks,
