preecep
Apr 24, 2013Novice
Stacking problems with GSM7328Sv1
I have 6 x GSM7328S v1 switches stacked using the AX742 stacking kits. Everything appears to working correctly, however, when pinging the stack management interface it seems to be dropping ping packe...
kofi
Apr 24, 2013Aspirant
As an idea, does 'show logging traplogs' give you some more informations?
(I thought that syslog doesn't show all the same things, but it also depends on how it is configured though)
