pingster400's avatar
pingster400
Static IP vs. IPv4 Network Interface
We purchased a few M5100-28G and M4100-50G switches a while ago, however we have an issue where even though you give the switch a static IP, the IPv4 Network Interface will still show up as 169.254.100.100/16. The static IP would be in the 10.25.1.0/23 range. Never had this issue with any other Netgear switches over the years, but only on these guys.
Tried different FW versions, with same result. Thoughts?
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    pingster400,
    Welcome to our community! :)
    You may change the management IP of both switches by going to System > Management > Management Interfaces > IPv4 Management VLAN Configuration. From there, you may set your specified IP address of the switch in order for you to access it.
    John
    NETGEAR Community Team
    • pingster400's avatar
      pingster400
      Thanks for your reply John, however this doesn't really solve the problem.
      For example, one switch I have already configured using static IP 10.25.1.51/23 which works fine.
      However after the switch rebooted, the IPv4 address reverted back to 169.254.100.100/16 with no DFGW.
      Ironically I have just logged onto the switch via our Windows DC on network 10.25.1.0/23 using a web brower to access the gui via 10.25.1.51/23 and the switch login screen appears and I can see the switch working, although the IPv4 address is still 169.254.100.100/16 with no mention of 10.25.1.51/23.
      On another note, on the 10.25.1.0/23 network if I gui to 169.254.100.100, then the switch login page still loads.
      Any thoughts on why this would happen?
      • JohnC_V's avatar
        JohnC_V
        pingster400,
        You may need to save your configuration first before rebooting the switch so that it won't be deleted. You may save your configuration in Maintenance > Save Config > Save Configuration.
        Your configuration changes are saved across a system reboot. All changes submitted since the previous save or system reboot are retained by the switch.
        John
ProSupport for Business
