sakiv's avatar
sakiv
Strange stack problem
Having strange probelm XSM4342S I have two switches port 24 on both switches are stack.
Switch A is mater and B is slave.  I switched off Switch A, B become master and file trasfer is not interrupted.
I switched on switch A then it becomes a stack member.  After 10 min Switch B is off , Switch A become master but file transfer on network get interrupted.
Tried with Switch B also to switch off first same thing.
Any suggestions ?
Thanks
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi sakiv,
    Welcome to our community! :)
    It is normal behavior for stacking to make the other switch as the Master once it turns off. May I know which switch using for file transfer?
    JohnCarloV
    NETGEAR Community Team
    • sakiv's avatar
      sakiv
      Sorry you mis understood. I know that’s the basic it should become master. My point is when I switch off switch b, why the file transfer then stopped why switch A not getting responsibility even it become master.
      • JohnC_V's avatar
        JohnC_V
        sakiv,
        My apologies. May I know where is the file transfer happening? Is the PC connected to Switch A or Switch B?
        JohnCarloV
ProSupport for Business
