rk_dzsi
Nov 11, 2020Aspirant
Switch 4300-28 unusal state
Hi everyone, I have four 4300-28 switches in the network which are in an "unusal" state. They're working well and all but after some days/weeks/months they get unoperational. They block traffic,...
msi
Nov 12, 2020Luminary
If you have access to a serial console and are able to log things to a remote syslog server, this could be helpful. Additionnaly you're not telling the current firmware you're running these with. I've experienced some weird multicast issues on older firmware that has been mostly addressed for what I can tell in current releases.
Keep in mind that these forums are not specifically monitored by Netgear support. If there is a sense of urgency I'd check with Netgear's support. You do have lifetime warranty on them, and given the right information and debug logs they are usually quite helpful gals and chaps.
- rk_dzsiNov 13, 2020Aspirant
Yeah sorry about that software version I forgot. It's 12.0.9.4.
But do I need to register the switches in order to have fully management functionalitys or is this only for other switches?
- LaurentMaNov 13, 2020NETGEAR Expert
Hi,
Now you're good, you don't need to register Fully Managed Switches (M4100, M4200, M4250, M4300, M4500 etc.) to access the full GUI/CLI
It is only for the Smart switches, I hope it helps
- rk_dzsiNov 19, 2020Aspirant
Hi Laurent,
yes, that helps alot.
But the fault state is still an issue... but maybe an update does. :-)
