Ray79
Nov 24, 2018Follower
Switch Advice
Community-
I am looking to purchase a managed PoE 16 port Gigabit switch for my home. I am very NEW to switches (NOVICE). It will be connecting my cameras, internet, home security system, TVs, etc....
DaneA
Nov 25, 2018NETGEAR Employee Retired
Hi Ray79,
Welcome to the community! :)
The GS116E-200NAS is the product order code for the GS116Ev2 switch being sold in North and Latin America.
Does your cameras supports PoE? If yes, I will not advise the GS116Ev2 switch. The GS116Ev2 belongs to the Smart Managed Plus switches of NETGEAR which gives user the flexibility to configure certain static layer 2 settings in order to improve network efficiency and performance. The configurable features are Port Mirroring and VLAN. Also, Smart Managed Plus switches does not support management VLAN.
I advised you the Smart Managed Pro switches of NETGEAR such as the GS418TPP. Smart Managed Pro switches has many of the benefits of a managed switch without the complexity or cost of a fully managed switch. With a Smart Managed Pro switch, you can monitor ports, configure VLANs, configure management VLAN and set prioritization, all with an intuitive Web interface.
The GS418TPP is a 16-port switch wherein all ports supports PoE/PoE+ on all 16 ethernet ports and has a PoE budget of 240W. For more information about its specifications, access the link below:
Furthermore, click on the link below to know more NETGEAR switch models that might fit your network needs:
DaneA
NETGEAR Community Team
DaneA
Dec 03, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
