KrustyK
Mar 12, 2018Aspirant
Switch drop PTP multicast
Hi , I try to configure a m4300 8x8f switch with three connected devices, a PTP source and two PTP receiver. But i have a problem, the switch seems to drop every ptp multicast packet. I have acti...
- Mar 14, 2018
Problem fixed, IGMP on master clock was is in version 2 but IGMP on netgear switch was is in version 3. Downgrade to version 2 and all works fine.
Retired_Member
Mar 13, 2018Hi KrustyK,
Sorry, I notice that you disable igmp on global config, so it will cause switch cannot learning PTP receiver info.
So please remove below config and try agian:
no set igmp
no set igmp header-validation
no set igmp querier
no set igmp proxy-querier
KrustyK
Mar 13, 2018Aspirant
Just to be sure, to remove:
no set igmp
no set igmp querier
I have to enter:
set igmp
set igmp querier
In the global config menu ?
But, in the web interface IGMP is enable, maybe it's a bug ?
- Retired_MemberMar 14, 2018
Hi KrustyK
It's IGMP snooping global config.
'set igmp' is for IGMP Snooping global config;
'ip igmp' is for IGMP global config;
According to your cli command display info, looks like port 1/0/11 and 1/0/13 didn't learn IGMP groups(224.0.1.129) member. One more question: Is the PTP receiver can generate IGMP report to join the groups(224.0.1.129)?
Could you please collect the IGMP packet statistics for port 1/0/11 and 1/0/13, the command as below:
show ip igmp interface stats 1/0/11
show ip igmp interface stats 1/0/13
- KrustyKMar 14, 2018Aspirant
Hi Retired_Member,
I've enabled igmp snooping and igmp with:
'set igmp' and 'ip igmp'.
But, I've a question, IGMP can works on Netgear equipments without IGMP snooping ?
Yes, my ptp receivers can generate IGMP reports, in direct connection everything works fine.
The results of:
........ 0
(M4300-8X8F) (Config)#show ip igmp interface stats 1/0/11
Querier Status................................. Querier
Querier IP Address............................. 192.168.2.2
Querier Up Time (hh:mm:ss) .................... 00:05:31
Querier Expiry Time (hh:mm:ss) ................ 00:00:00
Wrong Version Queries Received................. 0
Number of Joins Received....................... 0
Number of Groups............................... 0
(M4300-8X8F) (Config)#show ip igmp interface stats 1/0/13
Querier IP Address............................. 192.168.5.2
Querier Up Time (hh:mm:ss) .................... 00:08:01
Number of Groups............................... 0- Retired_MemberMar 14, 2018
Hi KrustyK
1. It's must enable global IGMP Snooping(but not necessary to enable on VLAN and port);
2. From the result of interface ip igmp status, looks like the port 1/0/11 and 1/0/12 didn't receive any IGMP report packet, the statistics is always 0.
