dgoodliffe
Nov 17, 2015Follower
Switch error message
Hi UNKN[196193840]: dtl_end.c(179) 7090 %% DTL avl mac delete error! Can anyone explain what this error above is about. I have googled it but cannot find the answer. Kind Regards Mr. ...
DaneA
Nov 18, 2015NETGEAR Employee Retired
Hi dgoodliffe,
Welcome to the community!
It seems you have already contacted NETGEAR Support about your concern. Let us isolate the problem. Kindly answer the questions below:
a. On what specific switch model/s are you seeing the error?
b. Did you modify the configuration of the switch/es prior in seeing the error? If yes, what are the changes you did on the settings of the switch/es?
c. Is the switch/es still working fine while the error is present?
I look forward to your response.
DaneA
NETGEAR Community Team
