OutOfMunich's avatar
OutOfMunich
Follower
Sep 07, 2023
Switch MS510TXPP - fan always on high speed
Hi all,
after changing the fan at my switch MS510TXPP, the fan is running permanently on high/highest speed (same speed as you starting the device). I have tried different fan versions and brands (including the orginal brand w/ same part no.), but no difference.
There is neither a speed reduction nor a speed variation anymore / as before. The fan led is off, thus I am expecting that the turning speed / tachoing is recognized by the device.
In addition I have tried to Reset as well as going back to Factory Defaults - no change in the issue.
The switch is running on the latest available firmware version 6.7.0.52
Anybody any ideas what I can try?...... I just want to come back to the factory defaults, so no modding or tuning.
B rds
OutOfMunich
1 Reply
  • schumaku's avatar
    schumaku
    Have requested a moderator to move this thread to the appropriate section on Plus And Smart Switches Forum to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management, as the subject MS510TXPP isn't a Managed Switch.
ProSupport for Business
