Midweek
Jun 16, 2022Aspirant
Telephony OUI "H%G-UNDEFINED-UNDEFINED"
Hi I have a GS748TP 48-port PoE Smart Switch (boot version 1.0.0.9, software version V5.2.0.11) and I am trying to add the Telephony OUI for some new poly phones with a OUI of 48-25-67. However ...
JeraldM
Jun 17, 2022NETGEAR Employee Retired
Welcome to the community!
There's no CLI for the GS748TP.
Is it also the same issue when you tried adding it with a different browser and/or workstation?
If possible, you could also try performing a reboot and/or a factory defaults to see if that resolves the issue.
JeraldM
NETGEAR Community Team
- MidweekJun 24, 2022Aspirant
Thanks JeraldM
We actually have a number of GS748TP's and it does it on all of them, regardless of browser used.
These are production switches so at this point I don't think I'll factory reset them just to get a couple of phones working.
Thanks for your help and suggestions though.
