QandA
May 20, 2019Follower
SIP telephony and VoIP -> QoS
Dear Ladies and Gentleman,
We are now using SIP telephony and VoIP in our Company. We need to make sure, all our switches are configured correctly for QoS. Sadly there are not actual guides for every switch we use in the “connection chain” from virtual telephone system to VoIP telephone or telephony software client in the firmware we use. Can you please help me set up every switch for SIP telephony and VoIP using QoS? Also there are errors in guides (for example https://kb.netgear.com/21757/How-do-I-configure-differentiated-services-DiffServ-for-Voice-over-IP-VoIP-using-the-web-interface-on-my-managed-switch) where text says go to xyz and picture shows what’s actually is right. Also first step of KB is reset after klicking “CoS Interface Configuration” again. And step 5 f and g are not selectable at the same time. I only can choose one! Also on M4300-28G ProSAFE I can/need to choose a “Policy Out Name” at “Service Interface Configuration” where at other switches there is only “Policy In Name”?
So first, these are the Switches we use, they are also listed in Model select at top of this Topic:
S1:
Switch Firmware count
JGS516PE 2.6.0.24 32
GS750E 1.0.1.4 1
GS752TS 5.3.0.31 3 (Stack)
M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ 12.0.2.15 1
S2:
GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port 10.0.0.53 1
GS750E 1.0.0.22 5
S3:
M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ 12.0.7.12 3 (Stack)
GS748TS V5.2.0.5 2 (Stack)
GS724T V1.0.3_35 1
These are the hardware and software client Telephones we use:
Alcatel 8038 Premium Desk Phone (Hardware Telephone)
Alcatel 8058s Premium Desk Phone (Hardware telephone)
IP Desktop Softphone for Alcatel-Lucent (Software client telephone)
Telephone system sets RTF to EF (46) and SIP to 40.
First to Switches
M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+,
GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port,
GS752TS
Here I can configure as written in your Guide https://kb.netgear.com/21757/How-do-I-configure-differentiated-services-DiffServ-for-Voice-over-IP-VoIP-using-the-web-interface-on-my-managed-switch . But there are problems as written in introduction.
From Step 1, Queue ID is not saved. I can only change “Scheduler Type” to “Strict” and “Queue Management Type” to “taildrop” and only if I don`t enter a Queue ID. If I enter Queue ID 5 and then reload “CoS Interface Configuration”, Queue ID is 0 again.
From Step 5, I should choose two options, but can only choose one. I guess g is the right one?
From step 7, guide says I should check only Interface 1/0/2. Why is that? I think I need to choose All because policy should be applied to all ports, right?
Is there anything more to configure I need?
I also set at QoS -> CoS -> Advanced -> IP DSCP Queue Mapping:
Interface “All”
IP DSCP 40=4
IP DSCP 46=5
What does I have to set at QoS -> CoS -> BASIC -> CoS Configuration?
Actually it is “Global” to “All” and “Global Trust Mode” to “trust dot1p
Next to Switches
GS750E
JGS516PE
Here I cannot choose any of above to configure. I only can set “QoS -> Global Configuration to “802.1p/DSCP Based”
Rate Limit doesn’t seem to apply.
I don’t know if we need “Broadcast Filtering”, what is common configuration for VoIP?
Last to Switches:
GS748TS
GS724T
These are old Switches, I does not have any options as above Switches. What do I have to configure here?
Please help! If you need any more Information, don`t hesitate to PM me. Thank you.
No RepliesBe the first to reply
