Jack1969
Jan 19, 2019Tutor
CM1150V Telephony modem
I just purchased a CM1150V Telephony modem. The Quick start gives a link to find out how to use LAN ports 2,3,4, but I cannot find the answer at this link. My port 1 works fine connected to my router, but when I plug port 2 directly to my PC, it stays yellow and it will not connect my PC to my network using the Ethernet connection. Anyone know how to use the other LAN ports?
> [...] Anyone know how to use the other LAN ports?
Someone might, but if Netgear published anything, then they hid it
very well.
Visit http://netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual. Read. I see:
Ethernet ports 1-4. For installation and activation, connect a
computer to Ethernet port 1. After you install your cable modem
and activate your Internet service, you can disconnect your
computer and connect a router to Ethernet port 1. Your cable modem
comes with plugs that cover Ethernet ports 2, 3 and 4. For more
information about Ethernet ports 2, 3, and 4, visit
netgear.com/support/product/CM1150V.
[http://www.netgear.com/support/product/CM1150V]
I'd've thought that "plugs that cover Ethernet ports 2, 3 and 4"
would be a hint. I'd also guess that you'd need a NAT router if you
wanted to connect multiple devices to any ISP connection which provides
a single public IP address.
> [...] I cannot find the answer at this link. [...]
Same here. Typical Netgear documentation.apparently the other ports are only for aggragation and cannot be used as a hub.
- DantepaceAspirantIf I have one lan PC and 2 wlan roku....my 2nd lan PC won't go into the web or do a speed check.
Very disappointed with the product...about to return it.- FURRYe38Guru - Experienced User
The modem needs a external wired router put behind it. Then you can connect all the rest of the devices to the router. ALL CM series modems are modems only. C series modems are modems with built in router and wifi features for future reference.
