ehoitinga
Jul 30, 2015Aspirant
"Timeout expired, please login again. Window will be closed" message when trying to access GS724TP.
Hi, I use a GS724TP switch for my home network which has 17 devices connected. To easy up network management I created a HTML page with a clickable map with a link to all my devices in it. When I...
- Aug 10, 2015
The switch UI likely include javascript code that prevent it from loading in another window and likely results in the execution of login output. Just for test try to change the link to html on your source page instead of javascript window loading function being injected and see if that makes a difference
<a href="http://switch-lan" target="_blank">http://switch-lan</a>
and see what happens. Or if you wish to debug if referrer is the issue you can do the test in chrome while using the inspector to watch the function Or you can likely check if the switch has Javascript function to block you by doing a inspector on the switch UI page and check for JavaScript function on loading session
Jedi_Exile
Aug 10, 2015NETGEAR Expert
ehoitinga
Aug 12, 2015Aspirant
Thanks for your answers.
I have changed my code to:
<area id="switch-lan" alt="LAN Switch (Netgear GS724TP)" title="LAN Switch (Netgear GS724TP)" href="http://switch-lan/config/authentication_page.htm" shape="rect" coords="5,557,729,587" style="outline:none;" target="_blank" />
to avoid opening the management page of my switch by the open.window javascript.
The results are still the same. A new tab is opened and the message "Timeout expired, please login again. Window will be closed" appears and I can only close the tab. Also tried "http://switch-lan/" in stead of "http://switch-lan/config/authentication_page.htm". It only opens the login page when I copy one of these links directly in an empty tab of my browser.
Can it be referrer check? I did found the inspector function in Chrome, but I am not sure how to recognise a referrer check. Also tried to disable Ghostery and ABP to see if these add-ons play a role in this problem. But no success.
Erik
