Ycommeyoyo
Sep 03, 2020Aspirant
Transceiver compatibility
Hello, Is the Netgear 10GBASE-SR AXM761 SFP+ Transceiver compatible with the M4300-24x24F switch ? It should be but I only see in the product overview that fits into SFP+ interfaces of M5300, M7100 ...
- Sep 04, 2020
Thanks!
schumaku
Sep 03, 2020Guru - Experienced User
The M4300 Series switch product datasheet is your friend - p.23
Ycommeyoyo
Sep 04, 2020Aspirant
Thanks!
