fawad9
Apr 02, 2015Novice
Trouble connecting Netgear Switch to Cisco Switch
Hi ,
I am having issues with switch setup. I am using CLI to configure ports as I am more familiar with CLI on Cisco switches. I am unable to setup a new management vlan with mgmt. IP on switch. Also I am unable to setup LAG (port-channel) with cisco switch.
I tried to follow the Software Admin Manual but it did not help.
Below is my config task and CLI configuration CONFIG TASK:
1. Create Vlans 511,541,542,535,592
2. Create SVI (interface vlan) for Vlan 592 and assign IP address to the SVI (172.20.4.x)
3. Create Trunk Port 0/23 and 0/24 and allow tagged vlans 511,541,542,535,592 on trunk port
4. Create LAG (port-channel) consisting of ports 0/23 and 0/24
5. Assign ports in each vlan as untagged vlan ports port 1 - 8 vlan 511 .......
6. The port-channel will connect to Cisco Switch. Please provide configuration guide to setup LAG between the Netgear switch and Cisco switch.
7. Allow DHCP packets to pass through the LAG
Current CLI config:
vlan database
vlan 511,535,541-542,592
vlan routing 592 1
exit
ip routing
ip route 0.0.0.0 0.0.0.0 172.20.4.1
line console
exit
line telnet
exit
port-channel name lag 1 po1
interface g23 addport lag 1
exit
interface g24 addport lag 1
exit !
interface g1
vlan participation include 542
exit
interface g2
exit
interface lag 1
vlan participation include 511,535,541-542
vlan tagging 511,535,541-542
exit
interface vlan 592
routing
ip address 172.20.4.4 255.255.255.128
ip mtu 1500
exit
1 Reply
- NhellieVirtuosoWhat's the model of the Netgear switch that you are using? *edit just in case you are using GS7xxxx series switch, check this article: http://kb.netgear.com/app/answers/detail/a_id/24251
