boe
Mar 14, 2017Luminary
Trying to change Switch to get DHCP address on Vlan 10 or assign it a static on VLAN 10
Hello, I'm not familiar with Netgear VLANs. My default data network is on vlan 10. My network has all the vlans controlled through the firewall (I do not want any routing through the sw...
DaneA
Mar 16, 2017NETGEAR Employee Retired
Hi boe,
Kindly post a .img or .png diagram of your detailed network setup as well as the screenshots of the setting you are trying to configure.
DaneA
NETGEAR Community Team
