UMJonny
Feb 03, 2024Aspirant
Two Portable M4250 - Both need DHCP
Hello. Two portable AV Racks. Some times they will be used together (fiber link via SFP) and some times they will be used in isolation. In both cases, however, i will need DHCP. Both switches are...
UMJonny
Thanks. I appreciate the response, but i'd like to understand a little more about what this is actually doing.
Can you refer to this in the manual or explain a little more?
Thanks!
UMJonny
Could i possible do this with DHCP snooping?
For example: configure a server and pools (different ranges) on each switch. Then, configure each switch with DHCP snooping that only trusted the Gig ports, and not the SFP? Then any DHCP requests from the SFP ports are dropped.
Thanks
