UMJonny
Feb 03, 2024Aspirant
Two Portable M4250 - Both need DHCP
Hello. Two portable AV Racks. Some times they will be used together (fiber link via SFP) and some times they will be used in isolation. In both cases, however, i will need DHCP. Both switches are...
schumaku
Feb 04, 2024Guru - Experienced User
System > Services > DHCP Server > DHCP Server Configuration.
Somehing like this:
AV Line of Fully Managed Switches M4250 Series Software Administration Manual Firmware Version 13.0.0 - Chapter 21, DHCP Server
UMJonny
Feb 04, 2024Aspirant
Ah, so you're suggesting that i just enable and disable one of the DHCP servers as needed. Not an option, unless i can do that via SNMP.
This is somehting that needs to happen automatically without an admin or programmer around.
Would the DHCP snooping idea work?
Thanks
