Simon1978
Apr 20, 2017Aspirant
unable to get CAM Table from GSM7252PS
I'm unable to get the CAM Table via snmp(dot1dTpFdbTable). Other snmp queries work. public@vlan doesn't work either.
- Retired_MemberApr 20, 2017
Hi Simon1978,
Welcome to the community!
Please use MIB node 'dot1qtpFdbTable' instead.
EricZ
NETGEAR employee
Retired_Member
Apr 20, 2017Hi Simon1978,
Welcome to the community! ![]()
EricZ
NETGEAR employee
- Simon1978Apr 21, 2017Aspirant
Hi,
Thanks for the tip! The index-value in that table was confusing at first. But now I get it. The first value is the vlan number and the following numbers are the mac-address in decimal.
Simon
- Retired_MemberApr 21, 2017
Hi Simon1978,
Correct!
With regard to resolve your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,EricZ
NETGEAR Employee
