letakhar
Jan 16, 2023Aspirant
Unable to set SFP+ Port to Auto Negotiate
We have multiple MS4300-28G switches and on 3 of them we are unable to set port 1/0/27 SFP+ to Auto Negotiate, We have a 10G SFP+ module connected and we need to be able to connect this to a 10G ...
- Jan 18, 2023
Thank you for all your help but I have found the solution to my issue
It seems that we have SFP+ modules from FS.com that are different revision numbers.
As such the Revision A modules are compatible with 10G-SR/1000SX thus when we plug in a 1GB media converter when the switch port is set to 10G it drops down to 1G and then allows us to plug in our test unit at 10G and the link is then at 10G. and the modules that don't have a revision or are labeled as revision B do not work in the same way
Im assuming that it is mainly due to the 1000SX compatibility.
Thank you
schumaku
Jan 18, 2023Guru - Experienced User
While an SFP+ RJ45 module allows to auto-adopt on different link speeds, there is no such feature available in the industry doing link speed negotiation on fiber ports and fiber links. Random side effect on your modules?
letakhar
Jan 18, 2023Aspirant
Thank you
