tomred
Aug 28, 2018Tutor
User Interface not displaying ports
I am trying to add vlan members to a port on my GS724TS but the UI is not displaying the ports. When I click on the untagged/tagged port members, I see this:
I cannot see how I can add p...
- Aug 28, 2018
Hello Dermot,
The pop-up is just informational. A slightly newer switch with the same Netgear Web UI does work fine in a current Chrome (Version 68.0.3440.106 (Official Build) (64-bit) here). Well possible these legacy devices might require a browser in a legacy mode.
If the amber areas (with the Unit selection at least) don't show up, double check there is no Internet "security" software blocking some JavaScript on your system. On Windows, worth a try would to bring up Internet Explorer (IE11) - if the "modern" more universal standards don't show the amber areas, enable the IE compatibility mode and reload the Web UI page.
-Kurt
schumaku
Aug 28, 2018Guru - Experienced User
Hello Dermot,
-Kurt
