Carlo_S
Mar 16, 2023Follower
Vlan between NETGEAR S350 series and Router Edge X
Good morning,
I would kindly need some information because I have problems of incompatibility between an Edge Router Ubiquiti X-SFP and a switch Netgear S350 series (GS324T).
I created a Vlan on the Ubiquiti Router, and with other systems of other brands it works. I also installed the latest firmware on your switch.
Are the two models compatible? If yes, could I know how to do the configuration on the Netgear S350 series switch, so that I can read the Vlan created with the ubiquiti router?
Thank you
1 Reply
Tell us the exact VLAN configuration on both devices connecting ports.
Have some untagged VLAN on the link and forgot about the PVID config?
