krobinson
Nov 10, 2013Tutor
VLAN communication between switches
I have a GSM7352 and a GS752 connected with a single LAG. I only have VLAN 5 configured on both switches. The ports on both switch are set for untagged and the LAGs are set for tagged. A computer is ...
krobinson
Nov 11, 2013Tutor
yes they are 192.168.0.24/24 and 192.168.0.188/24.
I start a continuous ping and move the cable from one switch to the other (both connected to the same switch) I get a response. After returning the cable to the other switch I get destination host unreachable.
I noticed in the logs of the GSM I get a "Link Down: vlan 5" and no reference to it coming up and on the GS there is no reference to vlan 5 in the logs.
