BKarrenstein
Feb 02, 2024Aspirant
VLAN configuration with active AutoVoip
Hello, i have few M4300. I have configured AutoVoip for the telephones and telephone system. Everything works smoothly. Now I need to add a virtual server to the same VLAN as the phones. This ser...
- Feb 02, 2024Just by using a trunk connection and a tagged VLAN 50 I fear...
schumaku
Feb 02, 2024Guru - Experienced User
- BrianLFeb 03, 2024NETGEAR Moderator
Hi BKarrenstein,
To accomplish this, you may want to manually tag all the phones in VLAN 50 and untag the VM (Virtual Server) and move away from using Auto-VoIP.
Kind regards,,
