YusufB
Aug 19, 2021Tutor
Vlan gets WiFi but no internet on only 2 AP
My network knowledge is a little rusty now im semi retired but thhis vlan issue is driving me bonkers...assuming its the vlan issue... Switch 1 Ground Floor: Netgear GS418TPP POE 16 port switch ...
- Aug 19, 2021
Sorted this issue...on switch 2 there are a few lags going to different servers and datastores elsewhere in the network...ticking that other LAG messed it up and VLAN traffic was trying to route to the internet through one server hosting DHCP that didnt have VLAN 30 access ...(had it ticked on switch 1 as well (happy click) but there was no second lag configured on switch 1)
Thank You schumaku for pointing this (silly mistake) out but happy its sorted especially on a Friday!
schumaku
Aug 19, 2021Guru - Experienced User
The LAGs are really configured on both switches? Reason asking you state each switch as a LAG made of port 1 and 2 - however we see two LAGs (the LAG 1 and LAG 2) selected on the VLAN 30 tagged both switches.
- YusufBAug 19, 2021Tutor
- schumakuAug 19, 2021Guru - Experienced User
So happy you have figured out the issue. Wish you a wonderful weekend!
