Rbmrk
Mar 15, 2025Aspirant
VLAN help
Hello, Ive been searching for some time and trying to get the better of understanding vlan of my GS728TPV3 switch. I cant seem to understand how this should work togheter with a TP LINK access poin...
Rbmrk
Mar 16, 2025Aspirant
Hi Schumaku,
I am not sure i understood it correctly but to simply put this:
I have a router first, providing dhcp, connected to netgear poe switch.
I then have an access point connected to the poe switch also, this AP broadcasts 2 ssid's, lets call first one "internal" and second one "external", this AP also has VLAN.
I dont mind if this management you are talking about exists on the same network as long as "external" ssid cant communicate with it. How do i accomplish this as simple as possible if it is possible?
I can turn on a feature "guest" on the ssid in order to block that ssid to communicate with my switch and router etc but id like to not turn on that feature if possible. (doesnt matter really)
Ive tried watching clips on people explaining vlan but i just cant figure out how i should set mine up at home.
Any helps appreciated.
schumaku
Mar 17, 2025Guru - Experienced User
The DHCP one does typically have on the consumer and SOHO routers is for one network, read for a single VLAN and IP subnet.
This represnets the common "LAN", aka. the VLAN 1, by default where your primary WiFi and by default all switch Ethernet ports are configured to.
Port [n] VLAN =1, [U]ntagged, PVID 1
If introducing an additional network, you talked of a VLAN 5 plus the associated SSID on the AP.
If not done already, create that VLAN 5 on the switch(es)
For the port connecting the AP
Port [nAP] VLAN 1 [U]ntagged, PVID 1
Port [nAP] VLAN 5 [T]agged, PVID remains at 1.
For one or some test ports for connecting e.g. a computer, for that VLAn 5
Port [nTest5-n] VLAN = 5 [U]nagged, PVID remains at 5.
Port [nTest5-n...] VLAN = 5 [U]nagged, PVID remains at 5.
Essential is that these ports for the VLAN 5 are -only- members of the VLAN 5, and -not- also on the VLAN 1
Now you have a test network for that new VLAN 5.
You will undoubted find that computer connected wont' get a LAN IP assignwed (in absence of a DHCP server on that LAN), so modern computers will fall back to the so called ZeroConf LAN IP subnet.
So for these devices to communicate (for learmning), either use the automatically assigned ZeroConf IP addresses, or define that VLAN 5 to be e.g. 10.5.1.x / 24 (255.255.255.0) IP subnet.
This should explain why I mentioned thaw lack of a DHCP server for that network before.
- DeclanJudeApr 02, 2025Aspirant
Thank you so much for the info. It helped me.
