hamajang
Nov 14, 2016Aspirant
VLAN Internet Connection and Access To Another VLAN
Hello, This is my first time setting up VLANs and I need help. I have the following equipment and IP settings: M6100 Chassis with XCM8944 Managed Switch Firmware Version 11.0.0.18...
- Nov 18, 2016
Hi hamajang,
Please add Named IP ACL such as:"VLAN_60" or special number IP ACL with "101-199" in Page (Security>ACL>Advanced>IP ACL)
Because only advanced ACL support extend rules to control destination IP address.It's my bad that missed this step.:smileyindifferent:
hamajang
Nov 18, 2016Aspirant
Hi Daniel,
Thank you for your example. It makes it so much easier when you include pictures. I am having a small bit of trouble, though.
I am able to create an IP ACL
However, when I go to Security>ACL>Advanced>IP Extended Rules I don't get any dropdown of ACL IDs to configure. My screen says, IP Rules, No ACLs are configured
I can go to IP Rules and create a Basic IP Rule Table, but I cannot configure destination IP ranges... only source IP ranges.
Am I missing something? Did I skip a step somewhere?
Thanks again.
DanielZhang
Nov 18, 2016NETGEAR Expert
Hi hamajang,
- hamajangNov 22, 2016Aspirant
Hi Daniel,
That was it! I changed the name of my ACL from "60" to "VLAN_60" and was able to add IP Extended Rules. The ACL works perfectly! Thank you for all your help with setting up my network VLANs. This is pretty cool stuff. I knew it could be done, I just didn't know the nitty-gritty configurations.
Again thank you for all your help.
- DanielZhangNov 22, 2016NETGEAR Expert
Hi hamajang,
It's my pleasure to help you.
Any posts is welcome when you need NETGEAR community.:smileyhappy:
