Ciscopete's avatar
Ciscopete
Vlan issue on GS108PEv3 - 8-Port Gigabit ProSAFE
Hi guys,   Having problem with following  , need to connect one of my shops to SP network. SP provision one the ports on patch panel to be part of the same vlan as other shops are connected to  , n...
  • XavierLL's avatar
    Dec 07, 2017
    HI Ciscopete,
    Welcome to our community!
    Seems that you are having some issues with the VLAN set up,  from what you wrote below seems that all ports will belong to this new VLAN , so you are not going to plug any device that doesn´t belong to the 2534 VLAN?
    If this is the case seems that the main issue is on the uplink port, you need to check it with your SP but normally what VLANs are they tagging ( normally they just tag their own). I would recommend to test to set up the uplink port with PVID 1 , an for VLAN membership you Untag 1 on the uplink port and Tag the 2534 VLAN. For all the other ports you can leave the configuration as it is and keep PVID 2534 on them.
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
ProSupport for Business
